I’m changing my header background image on scroll and would like to add ease to the extended attributes, but I’m not having any luck.
Billy
http://www.smartytest.com/Sarah
Billy
Can you point to an example (code) that you’re trying to match? I’m not familiar with this particular term as you’ve used it here.
Transition. Ease in 0.5s; ease out 0.5s
I’m using -WebKit-
Did you copy and paste this? Because there should be a hyphen between ease and out:
-webkit-transition: background-image 0.2s ease-in-out;
transition : background-image 0.2s ease-in-out;
(That’s copy-pasted from css - CSS3 background image transition - Stack Overflow)
Make sure that you add the attributes in this order (prefixed first, unprefixed last), that way when the browsers that are supporting it conditionally accept the full CSS3 spec, the code will still work.
I’m using -WebKit-
This is what I have:
all 0.5s ease-in-out; -moz-transition:all 0.5s ease-in-out; -o-transition:all 0.5s ease-in-out; transition:all 0.5s ease-in-out;
Your code looks a little different. Let me try that.
Billy
Still not working.
Are you talking about the part in .project-box? Try making that All lower-case.
On May 25, 2018, at 9:11 AM, billy kimmel email@hidden wrote:
Still not working.
No. It’s the “header” that’s it’s id
Okay, that syntax looks good. But what event/handler are you using to trigger the transition?
