I have to confess, I thought the new Pro 5.5 feature of HTML Email Creation was to create contact forms within Freeway (chalk one up on the Duh! column for me).
Is there any “easy” (and preferably free) way to set up a contact form?
The Softpress KnowledgeBase article gives a great overview on the subject;
I found an easy way to create simple forms is through http://www.jotform.com/. They have a form builder tool that will allow you to create the form and then gives you the code that you can paste into a “Markup Item” box.
Dave
I use Forms2Go strictly for being able to easily create sensibly formed emails that come to me. I doubt a novice could edit the PHPFF script produced by the action to receive the email in some sort of order since the action itself just throws information at you. Plus you can save settings in Forms2Go and with the PHPFF action if you change one thing, publish, you have to go back in and make all those changes again to the script. That’s no fun.
Forms2Go allows you to also have a javascript pop-up that occurs to let people know about validation errors while the PHPFF action redirects you to a separate page. This does raise the chances of your site visitors losing the information they entered previously if you use the PHPFF action while the javascript from Forms2Go still keeps the existing information intact. It can be a real pain working with the PHPFF action when working with long forms plus the support for Forms2Go is outstanding.
I use just the regular PHP version and have been happy with it.
