Hello,
Will I run into browser compatibility issues by using Easy Reflections vs using Photoshop to make the reflection and then bringing the whole image (with the reflection) into FW. In other words, by using the Easy Reflection action, since it uses PHP script, that some browsers may not support it and the reflection won’t show up.
Hello,
PHP runs on the server, and the number of servers that cannot run PHP is vanishingly small. That said, configuring an image modification script (if this doesn’t just work out of the box) can often be a can of worms. Try it. The only limiting factor will be your server, and how ready and able your hosting provider will be in assisting you with the yak shaving that may ensue.
That is interesting. I never changed anything. The action just stopped working quite sometime ago. I presumed it had to do with the update to 7. Thanks for letting me know. I will have to take a look again.
