One of my pages loads almost off the screen. I checked the
source code and see text relating to what had been an html block and a block of screen that is generated above the page layout (such as -50 to about -450)
If you use FW’s Site/Page view (left hand side of the FW window) - which is defaulted to Site. And select Page then that pane will display all the items on your page.
You can then select the one that is the problem and delete it.
Hi Dave,
Thanks for responding. I have done that and found nothing until I go to the preview pane. From there I see the text and a black block. Here is a link to that page I’m testing. I thought it might have to do with the way I placed the gallery file. I used EWA and first placed the .html file but that didn’t work so I went back and replaced it with the .swf file. I was seeing a Johnny.html file in the source code above my banner.
Hi Dave,
Your first suggestion in Markup worked. Thank you so much.
Not sure about you last post though. A .swf should be the
gallery I created in EWA.
