The site needs renovation but for now I just need to fix the recipients of the sendform action. How do I get to edit the page action? If I go edit>actions is gives me a global settings page.
The recipient is set in the Actions interface in the Inspector
The Recipient Address is the first field in the interface.
If you applied the Action to the page, then look in the Actions palette. If thatโs not visible, Window/ Actions will make it so. If you applied the Action to a table containing your form elements, then click once on that table (so the corner handles light up) and then look in the Actions palette.
