I am getting this “resources not found” error message when I upload a 3 page site. The site works fine and the files that are missing I don’t recognize. here is the error message. Thanks!
Go into the FW main menu and choose Edit>Resources.
In the Dialog box that opens you will see all the resources that are used in your Doc and next to each will be its status.
Any item with a Status of missing click on to hilight it and then choose Edit from the Bottom Right of the window.
Another dialog box will open and one of the options is Locate when selected will give you the chance to find your missing Resorces.
However from the Error you are showing it looks like you have trashed the Exhibeo Export and you may have to get it out of the Trash or re Export it first.
