[Pro] error
I inherited a website from a guy that created it in Freeway Pro. I’m using Freeway pro also to make it simple.
I keep getting errors related to the Moo Actions.
File not found:
necessary support file not found in action bundle.
Expected location:[[ Settings:mootoolsOptions.txt]]
Where would I find the missing file to load?
actionsdev mailing list
Go to http://coastalrugs.com/Actions and download the Action in its
entirety. Close the documents you have open in Freeway. Locate the
installation instructions (I think they’re in the download bundle) and
follow them precisely. This error means that you are working from an
embedded version of the Action, which Freeway stashes in the document
itself so that a document handed off to another developer who doesn’t
have the same exact Actions installed will still work. Only it doesn’t
work that well in the case of complex Actions such as this one.
File not found:
