The gallery does not fit the device??? I used your template… The exhibio slideshow is not responsive?
The purpose of this topic is to provide information about the migration from FreewayTalk and Groups io to Discourse and the differences in Discourse, as well as a place to discuss the good or bad of the migration. For those previously subscribing...
Reading time: 2 mins 🕑
Likes: 1 ❤
Caleb_G1
(Caleb G)
June 10, 2015, 3:47am
2
Patrick,
Are you using the latest version of Exhibeo (v1.1.3)? I know that some earlier versions did not output responsive Slide-themed sliders.
Likes: 1 ❤
Yes I am using 1.1.3 of Exhibio
Likes: 1 ❤
Caleb_G1
(Caleb G)
June 10, 2015, 3:57pm
4
Huh. Two few things to check:
Select the Exhibeo item in Freeway, and look at the inspector. The width should be set to 100%.
Right-click on the Exhibeo item in Freeway, and choose Extended . Is there anything is the <div style> tab? There shouldn’t be.
Likes: 1 ❤
Yes it is set at 100% and set to extended with nothing in the TAB.
Likes: 1 ❤
Caleb_G1
(Caleb G)
June 10, 2015, 4:13pm
6
Welp, I’m fresh out of ideas. For some reason, the JeweleryGloveandPolishingClothSlideShow element, which I think correlates to the action-item in Freeway, has a width of 1200px set through the style attribute, which is overriding the 100% set through the inspector.
'fraid I can’t help you on this one. You may want to reach out to Softpress support directly (this is just a community forum).
Likes: 1 ❤
Do the images need to be inline before making a slideshow?
Likes: 1 ❤
Caleb_G1
(Caleb G)
June 10, 2015, 4:34pm
8
The images themselves are already inline (however, you can’t even control this – all of that is handled by Exhibeo, so there’s no use worrying about it). The important thing is that the Exhibeo Import action item is inline, and from looking at your source code, it is, so this isn’t the problem,
Likes: 1 ❤
I did send a message to Softpress, i will update you. I did a new slideshow but it did the same bad responsive behavior…
Likes: 1 ❤
Have a look at the item id=“ShowcaseWrapper” in the Inspector.
Does it have a fixed height/width?
Likes: 1 ❤
Thank You,
Fixed(%)
Fixed
I tried all the different combinations…
Patrick
Likes: 1 ❤
Hmm - I’ve never used Exhibeo but try the following:
In Exhibeo, under help, run the install FW action. Apparently you have an older action-version (1.0.3) running (should be 1.0.6)
Likes: 1 ❤
… and by the way a word to the developers:
There is absolutely NO reason, why the “Exhibeo Import DIV” collapses to nil and nothing just by removing the w/h attributes to available and flexible. In a flexible world, this buddy doesn’t really require both attributes at all.
Could you have a look or even fix this, pretty similar to the pass-through image behavior, please? Just for the WYSIWYG pleasant, perhaps.
Likes: 1 ❤
Thomas You are the Best! We love Badenweiler and Bad Krozigen! We live between Switzerland and New York.
Thank you for helping me, that was 1 week of stupidity…
Vielen Dank!
Patrick
Likes: 1 ❤
You mean you shuttle? That’s cool - sounds delightful. Both cities are about 2 hours from me but I never visited them (it’s behind the mountains direction to Mulhouse). I’m more A81 oriented between lake of constance and Stuttgart (theSwabian).
Likes: 1 ❤
My wife was born in Koln. Her Father is from Dortmund and Mother from Dresden.
I love German women, the Very best!
Thank you for your assistance.
Patrick
Likes: 1 ❤
Thanks, Thomas!
I had the same problem and was trying to fix it for many hours and found the solution here. My Exhibeo action was also outdated
Best regards,
Marcus
Likes: 1 ❤
