Hi I have created what I thought a simple site www.purelettingsdevon.co.uk Trouble is client keeps selling and adding new properties… and my property list is becoming a nightmare! Has anyone a solution to make this part of the site easier to update, remove properties and add new ones? Thanks Simon
You can install a CMS to add new properties whenever you like, but you have used the Freeway slideshow so that would need to be thought about if you go the CMS route.
p.s. On your slideshows, you can turn off the navigation that appears on the image from within the actions pallet.
