I remain intrigued by this technique, but confess I really don’t understand it very well. I’ve read the documentation and fooled with it a bit, but never with any success.
Do any of you have websites you can point me to where you made use of this? Also, any advice on the “gotchas” that can mess it up?
I’ve made several sites using RPL and Pro 6, and all I can say is that “fooling with it” seems to be the best option. After a while, it gets much easier to troubleshoot and figure out what elements need to have the “Remove from RPL” action applied to them.
Thanks, Caleb. I’m going to be redoing two more sites soon. I just recreated a 36-page site under the gun, so used simply CSS layer layout. I’d like to experiment with other forms if I have more time for the other two. One is this RPL and the other is the box model.
