Used to have an Exhibeo slideshow and a FLV Player action item together on a web page, no problem. Now all of a sudden the .flv container is blank. Any ideas?
Exhibeo mailing list
What do you do for visitors that dont have Flash.
What I really mean is why bother with Flash at all?
And the FLV doesn’t appear to be in the Resources folder at http://shopuniversitycommons.com/Resources/UC.flv
Very odd. It was never in the Resources folder before, it was in the /html folder. Moved it to Resources folder, now it works. Website is being overhauled soon to get rid of Flash, need it to work in the meantime. Many thanks for your help!
Careful how you do this because if FW doesn’t know about the file it might delete/overwrite it.
If you just FTP’d the file to the server as a temporary fix then fine but FW may undo this the next time you do an upload and if you just stuck it in the Resources folder on your Mac then FW will ignore it at upload time.
Do you know why FP isn’t putting the file in the Resources folder to begin with?
Not without seeing your FW doc, action versions and whatever else is on the page.
More a question for support@
