Hi Ronald,
The flicker you are seeing is the difference between how the browser and the Mac are rendering the type on the page. When the Exhibeo transition starts the text is temporarily rendered by the video card and unfortunately it doesn’t do a great job at matching the weight of the text rendered by the browser.
One solution is to force all of the text on the page to use hardware rendering and antialias it.
Hi Ronald,
Can you be a little more specific please? I can’t see what the issue may be as the text appears OK now while the animation is running.
On 17 May 2013, at 11:06, Ronald Botman wrote:
I have an other problem with the way Exhibeo works in Safari.
The text is now OK after your solution, but the slide show made in exhibeo is doing strange I thought. Just check on several devices. iPhone, iPad and computer now looks good. Only the slide show does not work with Firefox.
Hi Ronald,
I’m looking at your page using Firefox 21 for Mac (the latest version) and it appears OK. The first couple of images were a little jittery while the page loaded but other than that it appears OK from here.
Exhebio is causing my page to flicker every time the slideshow transitions. Funny thing is, this only happens with Safari. It works with no problem on Firefox, it even works fine on my cell phone as far as the flickering.
