[Pro] Exhibeo slideshows not working, why?
The two images, one the mechanic in the wash bay and the other the red Chevy hot rod are both Exhibeo slideshows, but they are not animating as they should.
I have been using Exhibeo for many years now and this is the first time I have had a problem like this. Can anyone tell me what is wrong, please?
TIA,
Robert
https://rogersautoelectric.com/
Exhibeo mailing list
Hi Robert
Maybe this thread may help?
Apparently some slideshow options aren’t exported as they should be so you need to insert the code manually.
Gordon
Hopefully, this thread will help and I will give this a try later this evening.
So, in other words, something was changed with the Exhibeo app since I last used it successfully?
Thanks for the help Gordon and I will check back later.
