[Pro] Exhibeo with Backdraft Fixed Header
Hi all,
I’m using Backdraft and have just installed an Exhibeo2 slideshow ‘Thumblie’ onto the home page.
As I have a backdraft fixed header, when I scroll down the page, the content generally goes behind the header which is great.
However, the exhibeo slideshow goes over the top of the header. This also affects the CSS menu drop downs which can’t be seen in full due to the slideshow hiding the bottom options under the ‘help’ option.
I think this may be something to do with ‘Z index’? Not sure.
Any help would be appreciated before I pull out my remaining bit of hair.
Many thanks,
Neil
eye style uk . com
For once I can probably help.
Select your slideshow item, or container - then from the Item menu, choose ‘Send to back’
Neil,
Select the fixedHeaderWrapper element using the sidebar. Now, got to Item > Extended in the menubar, and switch over to the <div style> tab. In there, add a entry with z-index as the name, and 100 as the value.
‘Send to back’ won’t work in the scenario because you are using inflow construction.
Damn!
Grant,
Thanks for your response, I’m sorry your advice wasn’t quite what was needed.
Caleb,
Great stuff, thanks very much, superb as always. I hope I’m doing your backdraft system justice. It is awesome.
Thanks again,
Neil
