Hello Panel. I love Exhibeo and use it all the time, but have a suggestion to make. From time to time users ask if it is possible to put the text below the images, instead of over the top. The reply is that the text box has a variable size which makes things difficult. What about having a text box of three or four lines in depth, but adding a scroll? I would find this very helpful. Cheers, Paul
I didn’t receive a response to the above, but here is an additional supporting thought! Even a relatively short text badly overlaps the photo when viewed on a mobile.
Paul
I had a look at your site but couldn’t see what you theme you were referring to. Could you send a link to the page that shows what you’re seeing please?
Cheers!
Paul
Hello Joe. Any of my cathedral sites – there is a title page, then a plan (sometimes) and then an Exhibeo page. It is the Exhibeo slides with text that often run into trouble.
I’m open to suggestions David, but with over 200 websites I’m reluctant to try to create separate site formats for mobile phones. Exhibeo works well for me in general, and I thought adding a text scroll might be a simple solution to my problem. Another and perhaps simpler idea might be to have a hide/show button for the text?
