Hi there, Is there any option in Exhibeo to show or extract the EXIF-information? If not, is it already planned for one of the next releases? Best regards, Ace
I’ve not tested this, but does Exhibeo even preserve EXIF information
already in imported images? Does FWP? My guess would be no, but it is just
a guess.
Darn, you guessed correctly. No EXIFs in the imported images. Too bad. For a photography site quite a bad idea
So the question goes to the Softpress folks:
Any plans to preserve the EXIFs in the first place and 2nd offer a way to display them (or a chosen subset) in the picture comments?
The only way to do this currently is to open up your Exhibeo export file (right/control click and choose "Show Package Contents”) and swap out the images for your EXIF loaded images. Note that you’d need to do this each time you made a change in Exhibeo. You won’t need to reselect the export file in Freeway each time you do this though.
