Hi All
Is there any way that an iFrame can be expandable??. Have a look at Loading...
Regards
Lee
Hi All
Regards
Lee
Yes, as long as the page you are showing in the iframe is part of your
site. If it’s from a different domain than your server, you won’t be
allowed to communicate between the two pages (the page in the iframe
has to “talk” to the page that holds the iframe for this to work).
On Jun 7, 2010, at 6:09 PM, Gray Owl wrote:
Hi All
Is there any way that an iFrame can be expandable??. Have a look at brutontown.co.uk
Regards
Lee
Thanks for your quick reply, Walter
Regards
Lee
has to “talk” to the page that holds the iframe for this to work).Walter
Hi All
Regards
Lee
