I want to add a box that will contain an external graphic that will link to that external page. It is a banner from another website. The other website provides me with a code to the graphic and that will allow others to access that page. What sort of a box do I use? Thanks!
Show us the code but it is likely that you want to use a Markup Item
Insert>Markup Item - paste the code into that, OK it and then resize it to suit the graphic you are displaying.
You can then position it wherever you want on your FW page.
Delta Dave,
That is the exact answer. Thanks so much!
