Below is an email from a facebook page developer- I need to know how to add the code to a link, so that when she sends me the “like” code, how do I add it to the link when clicked?
I have to embed special code that will add a “like” just from them clicking on it. It’s not just a link to the page. I can send the code to embed if you wish, if you know how to do it.
I don’t know if the Like can be added to a normal text link. The ones
I have seen require that you embed their JavaScript into your page,
for that you would use a Markup Item or the CrowBar Action to place
the raw code into your layout where you would like it to appear. You
won’t be able to change the way that button looks (very much) and you
will be opening that giant security/privacy hole I mentioned earlier.
