I’m trying to create a remote rollover that fades in upon trigger, then fades out when leaving the triggering graphic. What I’m getting is inconsistent (http://www.swpagency.com/dan/ro2.html). Triggers are in the first column, each graphic.
I’ve been using the CSS rollover action combined with the Transition FX action for the trigger, then using the Target Show/Hide action for the larger image. Just can’t make the transitions seamlessly work together.
