Here’s the problem.
I have a graphic image area going across the width of the web page, size is 1024 px wide by 200 px deep. I’ve made
3 jpegs which are exactly that size and they are supposed to be stacked Target show/hide layers which fade one right after the other in a loop.
I have set up each of the three images as show/hide target layers, 1, 2, & 3, each set to initially show, all are sticky, all set to fade. I set the sequence timer to loop, run on page load, and all target numbers are set 1, 2, 3 to yes.
When I test it in the browser, only image 1 fades to image 3 and image 2 never shows up at all. I can’t figure out what I’m doing wrong.
Any suggestions, anyone?
I believe you should have the images set to Initially Hidden, well that is how it works for me.
Hope this helps.
john
same for me
Elizabeth
Hope this helps.
john
Have 1 duplicate base image that has no action applied - the rest (3) stacked on top initially hidden and sticky.
Thanks Delta Dave. That fixed the problem, it is working as it should now. Setting that static base image was the key.
