Hello all I need a little help. I usually have an easy time making a fading slideshow, but this time I want to use a folder as I have 13 images. It will not work. When I click folder it will not open. I have made all images sized and gifs web ready. i do not understand. anyone have ideas?
yes they were all jpgs first and that did not work. I ditched the fading slideshow and used Sequence timer instead. it works perfectly. I had forgotten about the built in slideshow Scriptilicious
thx anyway. I never was able to get the folder action to work before anyway
I tried that too but it did not work… no problem now. I like the Sequence timer
same thing anyway isn’t it?
while we are at it can someone tell me how to add text to each image. I made graphic boxes and ticked Fading slideshow for each file…at first I tried to use HTML for each image but you can not use Fading slideshow for HTML. There is no action tick, only shows up for graphic boxes…interesting
