Hi Panel! I posted a similar message to this a few days ago before going on holiday, but it seems to be lost. On the given page, a click on the photo triggers a rollover which makes the text disappear. I want this to happen on the next pages (right arrows), but nothing happens. While away I wondered whether I had had the CSS layout button off, but reworking the rollover with this button on hasn’t fixed the problem. The settings on both pages look the same to me … . Help please! Thanks. Paul
http://paulscottinfo.ipage.com/adelaide/churches/stgeorges/index.html
I am looking at the code but not seeing the Rollover/Click event being attached to the stgeorges2.jpeg
Was the action applied directly to this image?
Hello David. No, the rollover in each case is applied to the master page. In the case of the index page, the master and the actual page are the same, so everything works. The later pages in the site use the same (second) master. I’ve just noticed the boxes Use Master Contents/Settings which are unchecked for page 2, but interestingly the following page works without these being checked.
http://paulscottinfo.ipage.com/adelaide/churches/clayton/14.html
It’s a puzzle!
Paul
Is it applied to an image on the Master page?
I think you should go back to that page stgeorges/index and remove the action and reapply it to the image.
OK David. If I do that and the click on Reapply Master, it seems to have the required effect. Do I now have to apply the Reapply Master to each individual page?
Thanks for your help. It’ll be good to get this working!
Paul
I dont think that you need to reapply the Master - just the Rollover itself and only on pages that dont work.
Thanks for your time Dave.
