I have been trying to integrate Fancy Zoom into my freeway pro page. I have read the previous posts on Freewaytalk and have implemented these. The files are up on the server in the root directory and I believe everything else is in place. However it still just loads the images in a new page. Any advice??
This is strange; I’ve got it working here: ontwerpzaam.nl
But for some reason your’s doesn’t … the only difference I can find between our setup’s is the positioning of the Javascript reference. Your’s is right after , mine is right before .
The script is the same, the links are set up the same way, the onload is set up in the tag.
That couldn’t be it, it’s only JavaScript, not a server-side language
(which wouldn’t run on .me). Take a look in Firebug and see what if
any errors are being thrown there.
On Jul 29, 2009, at 12:33 AM, mtedwards wrote:
Just checking its not just because its on a mobile me server is it?
Update on my Test Link: http://louslittle.com/FZ_Test01/
On this “site” the additional pages are active and they explain how I
did it.
the problem you are having, I believe, is related to the javascripts
not being in the correct path on your server
My site above talks about the javascripts paths
LLE
On Jul 29, 2009, at 12:30 AM, mtedwards wrote:
Hi Guys,
Wonder if anyone can give me some advice.
Brilliant … thank you so much for your help… Its working now.
The only issue I have now is that it not loading other images. ie the X to close the large image. Although I am pretty sure I read something about this yesterday so will look back and see if I can find it.
Thank you so much again. This is a great product and will stop me from using excessive Flash on my pages.
