[Pro] Fancybox and WebYep
and suddenly fancybox isn’t working in all the websites I build anymore. I use it by putting it in the program>opt folder of the webyep-system and this used to work fine.
Anyone can help?
regards
Same problem here, not at every website I have built with WebYep and Fancybox, but with a few I have exactly the same problem.
It just stopped working…? Tried different/latest versions of Fancybox in the opt folder but no luck.
Someone any idea what is causes this problem and how to solve this?
Op 15 feb. 2013, om 09:21 heeft dadooper email@hidden het volgende geschreven:
Anyone can help?
regards
If you can post a link to an affected page we can have a look.
Here are two examples:
Http://www.dj-mathon.com
Http://www.campsconstructies.nl
Sorry second one is:
Http://www.campsconstructie.nl
The requested URL /webyep-system/program/opt/fancybox/jquery.fancybox-.pack.js was not found on this server.
That was on the campsconstructie.nl site
Your code is
should it not be
Besides FancyBox is now at version 2 Fancybox | Best JavaScript lightbox alternative
The dj-mathon site was throwing up some JS errors relating to FancyBox
Will have a look at it. But strangest thing is everything worked fine till a couple of days ago. Nothing changed. No new upload or webyep update. Just stopped working on several websites at once.
Thanks for your help
Hi Dave, if you don’t mind, I have send the urls off list.
I don’t want them indexed by Google in relation to this forum.
@dadooper, I did a test with an old version of Lightbox, this was working fine. If you are interested contact me off list.
Forgot to mention, version 2 doesn’t work either.
The reason why its not working is because jQuery was updated recently and it looks like it broke quite a few jQuery plugins (lots of wordpress sites went caboom as well). Anyway one plugin that seems to be affected is fancy box so untill the creator of fancy box updates his plugin you will need to install the compatible jQuery script which you can download form me here:
www.max-izzat.co.uk/jquery-1.8.3.min.zip
All you need to do is unzip the file and then place the file within the opt folder.
The full path is: webyep-system/program/opt
Then it will use this version which is compatible with fancy box rather than 1.9 on Google severs
all the best max
Thanks Max,
everything is working again now.
All the best.
Once again Max saves the day :slight_smile:
