i finished designing my site and wanted to see if it worked. hit the browser button and got a dialog warning as follows: could not complete the ‘publish site’ command because file not found. (43:271:207)
this has never happened to me before. i didn’t do anything differently than i’ve ever done before. i am clueless and obviously very frustrated. started over, rebuilding the site. i have rebooted my computer. i have restarted the program. nothing works. i reopened old files and nothing is working now.
i was originally using internet explorer. just switched to safari. didn’t work.
Open up Edit / Resources and press Resample All. If you get the same error, see if you can figure out which file is causing the problem. Another thing to do is delete everything from your site folder and publish again.
One question: you haven’t linked to any of the files in your Resources folder by any chance, have you? Those files are constantly deleted and re-created each time you make a change to your site, so that’s a very bad idea. Always maintain a separate folder (Freeway will name this “Media” if you use one of the templates to create your site) where you keep the originals of all of your assets. This will keep everything centralized and make it much simpler to move the document to another computer or a server for backup.
walter you are a genius and a quick one at that!
i am a print designer and i get so stressed out doing this stuff! thank you so much!!!
e.
e.
On Aug 8, 2013, at 2:04 PM, Walter Lee Davis wrote:
Which suggestion was the magic bullet?
e.
so now i have another question.
do you have any idea why freeway is now not recognizing links to youtube?
i’m following the directions [and i’ve done it before ].
what’s wrong? do you know?
oy.
e.
e.
i finished designing my site and wanted to see if it worked. hit the browser button and got a dialog warning as follows: could not complete the publish site command because file not found. (43:271:207)
this has never happened to me before. i didnt do anything differently than ive ever done before. i am clueless and obviously very frustrated. started over, rebuilding the site. i have rebooted my computer. i have restarted the program. nothing works. i reopened old files and nothing is working now.
i was originally using internet explorer. just switched to safari. didnt work.
