For anyone who uses the firebug plugin in Firefox
There is now a Firebug light action for freeway. over at actionsforge.
The advantage with this is even though it’s not as comprehensive as the real fire bug plugin it does at least allow you to debug in all the browsers: IE, Chrome, Safari and yes including Freeways own preview.
Just remember to remove the page action when you have made your adjustments for real otherwise your HTML page will have a permanent firebug button on the bottom right corner.
So as the costa coffee staff are always telling me in there slightly bored tone…
enjoy
:o)
enjoy
:o)
Hi Dan if you publish and look in freeways preview you will see that the firebug logo/button apears in the bottom right hand corner.
I was using exactly this method yesterday when I wanted to view what would happen when I increased a font size of an item within a table cell… I could quickly go up and down in size untill I found out when the size effected the table cell depth… then I just flicked back to artwork mode and changed the to size I had settled on.
