I would like to add a five star ratings system to my clients website, similar to Amazon customer reviews. My client would like me to add a five star ratings system to each of the pictures on this page, so several five star ratings on one page, please see link below.
I’m not knowledgeable with code but know Freeway reasonably well. I would really appreciate any help or suggestion and thank you in advanced for your kind help and understanding.
If anyone could write an action for this I would willingly pay good many, thank you.
Can you mock up (on a separate test page) how you would like the feature to look? Where would the stars fit into this fairly full page? Where would the comment form appear, and where would the comments appear once given? Would you want the stars to drive the sort order of the rated items?
I don’t see any instance of the Rating Widget on this page. Did you have it applied on a different page?
On Nov 5, 2013, at 8:57 AM, Paul1970 wrote:
Please can you help?
Thank you for getting back, greatly appreciated. I’ve made a mockup of the sort of thing I’m looking for. I don’t want comments, only a star rating system. Please see link below……
I removed the “Rating Widget” from the other page, but I’ve tried to add it once again on this page so you can see what I may be doing wrong, it’s placed under the last Buddha purple pic.
You’ve solved the problem, many thanks I really appreciate your kind help and support. It was a password problem with rating-widget like you suggested, the new updated Safari remembered the wrong password.
