Hi,
I am doing a ‘Product Selector’ for one of my sites and am having a problem with my fixed widths in responsive layout not behaving.
In the example, I have set the “MATCHED-PRODUCTS” block to be fixed width % for different media sizes. In Freeway, it appears fine, but when I preview in a browser, it is oversized within the fixed width window. Hope that makes sense.
For example, at 1024px wide, “MATCHED-PRODUCTS” should be at 60% width, but in the browser it clearly is wrong.
As far as I can see, I have no ‘available’ widths specified. It is all contained.
If anyone can help, I would be most grateful. Thanks.
HTML5 and a compatibility mode of IE7 simply doesn’t fit. Set the comp mode to “normal”, thus avoids breaking the layout into “tables”.
Furthermore I think that most of your “manually” placed code is simply on the wrong position. Some belongs into the before end head-Tag, others could be placed into the before end body-Tag.
Fix both and let us know. Then chances will increase to target “real” problems.
