[Pro] Flexible Footers
Hi,
I am using FW 5.4.3 and I am not sure whether I can achieve this.
I want to create a flexible footer. I can fix them to the bottom of the browser OK but don’t understand how to achieve what this site does:
Here you drag the browser window and the footer follows
covering up the content as it goes. This is what I am after so information contained in the footer is always available. I have tried searching but to no avail unless it’s a particular effect I don’t know the name of.
Can anyone help?
kasbah
I’d be interested to hear about this effect as well.
C.
On 3/2/12, kasbah email@hidden wrote:
Hi,
Il Gufo: Clothing for children and newborns - Il Gufo
Can anyone help?
kasbah
Try drawing an HTML box across the bottom of your screen, setting the Position picker in the Inspector to Fixed in Window, and using the position fields to pin the box to the bottom of the window. In the Inspector, by default, all measurements are taken from the top-left corner. But if you click on the icon to the left of the Top dimension field, that will be disabled and the Bottom field will be enabled. Set that value to 0. Next, set the left and right to 0 as well, (this should disable the width field). Your footer will be stuck in place and (as long as you don’t also center the page) full-width.
On Mar 2, 2012, at 2:19 PM, kasbah wrote:
Hi,
Can anyone help?
kasbah
Hi Walter
I am also interested in this idea, but when I tried it on a test page an viewed in in Preview, the footer does not stay in position. Your help is appreciated.
kind regards
Elizabeth Christie
Join my news alert
Ph: +61 (0) 8 8121 7744
+61 0415 848 407
E: email@hidden
W: www.schooldaysmagazine.com
Follow on Twitter
Follow on Facebook
Hi,
Can anyone help?
kasbah
Did you choose Position: Fixed in Window in the Inspector? That does the trick here.
On Mar 2, 2012, at 4:52 PM, Elizabeth Christie wrote:
Hi Walter
kind regards
Elizabeth Christie
Join my news alert
+61 0415 848 407
E: email@hidden
Follow on Twitter
Follow on Facebook
Hi,
Can anyone help?
kasbah
Yes, I did
kind regards
Elizabeth
Hi Walter
kind regards
Elizabeth Christie
Join my news alert
+61 0415 848 407
E: email@hidden
Follow on Twitter
Follow on Facebook
Hi,
Can anyone help?
kasbah
Hi Walter,
Again you have helped me. Marvellous! You ARE the resident guru.
It all works (of course) and you are right, it doesn’t work when aligning the page ‘centered’. It is dictated by the page width through ‘Fixed In Window’ command. So I experimented further to try and achieve this.
I changed the pasteboard setting under Document Setup to much wider than any browser would open out to.
I then reduced the view page size down so to see the new pasteboard size, then dragged out the HTML box left and right extending far beyond the page.
Previewed this and there we are, a bar glued to the bottom of the browser wherever you drag it height and width.
To make it cover the imported graphics on the page > Item > Bring To Front does it.
That is what I was after - so thanks again Walter for pointing me in the right direction!
Hope this helps Elizabeth and Carol too.
Until next time - and I’m sure there will be, bye for now.
kasbah
I’m not really sure if what you describe here is really a recommended and working method (after all I’m not sure if mine is).
Basically it’s about “Fixed items” in gerneral but I also tackled the fixed footer stuff.
http://kimmich-dm.de/screencasts/fixeditems.php
So you could probably try this method?
