[Pro] FLIP BOOK
Anyone have any idea how to create a “flip book” (using photographs-jpeg’s)
inside 5.5 ? Already tried page-flip - not user friendly.
Thank You
Sorry, which one is that? If you mean the kludgy script I wrote a
couple years ago, yes I agree it’s very unfriendly.
Banner Zest has some photo book templates that are easy to use…$129 to purchase the pro edition.
If you are lucky (or unlucky) to have Adobe InDesign CS5 there is a feature to create a flip book “flash” export right out of the box.
If you are stuck give me a shout.
David Owen { Freeway Friendly Web hosting and Domains }
http://www.ineedwebhosting.co.uk | http://www.PrintlineAdvertising.co.uk
Thank You
Vertical Moon’s SWF 'n Slide Pro has a simple flip book option which I used here:
http://www.thecakecompany.net/design.html
You can use the buttons or click/pull the corners. Take a look at:
http://www.verticalmoon.com/products/swfnslidepro/swfnslidepro.htm
HTH Colin.
