Tobias_V
(Tobias V.)
August 10, 2014, 3:38pm
#1
Hi.
I have a problem. I have a main html container that includes 3 other html container (inline).
The main container has 100% width and a flexible heigh. The 3 sub container has a fixed width/hight.
When I set the alignment of the sub container to left float, it kills the flexible height. You can see a example under: http://www.tobivoigt.de/floatflexibleProblem.html
When I set the alignment to center for the 3 sub containers, the flexible high works perfect. Here you see a example: http://www.tobivoigt.de/noFloat.html
Has anyone a idea why the floating kills the flexible height and how I can fix that?
Thank you.
Try adding overflow hidden from the inspector pallets
http://www.ineedwebhosting.co.uk
On 10 Aug 2014, at 16:38, “Tobias V.” email@hidden wrote:
Hi.
Thank you.
Or Auto
Or you can Float the parent…
Or use Clearfix - theres an action for that!
Tobias_V
(Tobias V.)
August 10, 2014, 5:04pm
#5
Overflow hidden and overflow auto works perfect.
Thank you!
