Hi Claude,
I’ve just updated the Action for Freeway 6 and specifically to deal with external styles. There is still an outstanding issue with the Action in the current version of Freeway 6 Actions API but that shouldn’t prevent you from using it now. You’ll only face an issue if you add border styles to your ‘snowflake’ layer item.
You can download the updated Action here; http://www.freewayactions.com/product.php?id=028
On 22 May 2013, at 13:05, claude wrote:
Does someone know if there is and upgrade to the Flurry action for FW6?
Tx Tim! It worked fine but I manually had to remove the old action file (1.0) flurry.fwaction from its location in ~/Library/Application Support/Freeway Pro/Actions/General/.
Then I reinstalled the new file and it is now snowing in my web site in www.celticcenter.eu Great!
