I downloaded the Flurry action and seem to get html code in a spreadsheet and do not know what to do with it so the action appears in FW Pro 7.
Appreciate help!
Thanks Stefan - Australia
Hi Stefan,
I suspect you double-cliecked on the Action file which (like my Mac) opens the file up in Numbers 9the .fwaction file extension appears to be registered to that application). Close Numbers and drop the action file on top of your Freeway application icon. You should see a (badly worded) dialog asking if you want to install the Action. Click OK and the file should be installed. You should be able to apply the Action to your pages as set out in the Action instructions.
Happy flurry-ing!
Appreciate help!
Also, in Finder, click once on the downloaded Action file, and choose File / Get Info. Mid-way down the inspector that opens, locate the Open With section. Choose Freeway, and check the “always open with” or “open all such files with” checkbox (don’t have it in front of me, you get the idea) and then you won’t have this problem any more on your Mac.
On Aug 1, 2014, at 12:46 PM, Tim Plumb wrote:
Hi Stefan,
Happy flurry-ing!
Appreciate help!
