Thanks in advance for your help.
I’ve been using flush videos and the FLV Action on some of my sites with 5.4.2 Pro and had no problems ( see Videos | MELODY MOORE or the reading page in Readings | Thomas Lisenbee). Trying to do the same in 5.5Pro I can’t find the controls placed under the movie box. In 5.4.2 I had an option to place it “under”. In 5.5 I have different options:
Player: Custom Player, Over, Glossy or none
Player File: none or select
Action script: 2 or 3
Tried some options listed above and managed to place the control over the movie right in the middle so it is covered by controls while is plying.
I am supposed to select a a player from a pre-defined list or select my own??? see below:
"1. Choose FLV Player from the Actions toolbar pull-down or from the Insert menu, and draw an item on your page.
2. Open the Action palette from the Window menu if it isn’t already open.
3. Select your FLV file from the FLV File pull-down.
4. Choose the Actionscript level you want. If you want to take advantage of the fullscreen option in Flash, then leave the option on its default If you have a custom player you will need to choose the level that the player is using. Note: you will need to contact the author of the player for this information if it isn’t already available
5. Choose the player from a pre-defined list or select your own. Note: the Action only supports standalone FLV Playback skins - some downloadable skins will require the movie to be self-contained, hence edited and embedded manually
6. If you require transparency to be used (the default background is white) then check the Transparency option
I do not have a pre-defined list or my own player that I know of.
Can anyone help me with this please???
DD
