Poor old Sawftpress Towers. I know they’re rueing the day I bought Freeway.
So, I’m experimenting with making some Styles to keep for formatting graphic text in corporate colors and font style. Styles should be…
- Frutiger Light in WebMustard,
- Frutiger Roman in WebMustard,
- Frutiger Roman in WebChocolate.
- (Among others, but that’s enough to give the idea.)
Can’t figure out how to do this. Every time I try to make styles 1 and 2, they replace each other. I can’t have both. Suspect it’s because FW won’t differentiate between the submenu Frutiger Light and Frutiger Roman. Choosing between the two gives only the Frutiger in the Edit Styles dialog.
Anyone have any idea how this could be done?
Strange. Are you creating NEW styles, with new names, each time?
In the Styles & Colors palette, choose New Style from the cog wheel
popup menu. Name this something like FrutigerLightMustard and set the
Character options as appropriate. Click OK, then make a new style =,
with a new name, and choose your Roman weight of Frutiger. Click OK.
I just did this and got two separate styles that format graphic text
as Frutiger Light and Frutiger Roman with no problem. Yes, the main
font menu in the Styles dialog just shows the font family name, but
it does remember the particular weight and style that you select.
Try this. It works here, and I’ve done this sort of thing more or
less forever.
k
Well, I’ll be a monkey’s uncle. It worked.
I think the problem was trying to edit already existing temporary styles. Creating new ones from scratch worked a treat.
Although I used the plus-sign button, not the cog wheel. I wanted to add them to my existing sheet.
But here’s a question. Did I want a new sheet for styles that are only graphic? To distinguish them from CSS styles?
Nice idea, but Freeway can only handle one sheet at a time.
So, unfortunately, you’ll need to keep all the graphic styles in the
same sheet as the HTML/CSS ones.
Heather
Sometime around 2/5/10 (at 09:23 +0100) Heather Kavanagh said:
you’ll need to keep all the graphic styles in the same sheet as the
HTML/CSS ones.
Don’t even think of things in terms of style sheets, not until you
hit a positive reason for doing so. Those graphic styles aren’t
published in the final CSS stylesheet code that’s part of your online
site.
Give them names to differentiate them from HTML/CSS styles if you
like. Here’s a thought: putting “GRAPHIC” at the beginning of the
names will help group them in the Styles list.
k
Okey dokey, I’m accustomed to using naming conventions to organize stuff. In fact, amongst a small circle of friends, I’m notorious for obsessively insisting on it.
But, If FW “can’t handle” multiple sheets, why have the cog wheel giving me what seems to be the option to create them? FW does such odd things some times. I can’t keep it all straight.
Never fear, it can handle it. But I didn’t see any particular reason
for you to work that way. You were talking about styles for graphic
text, whereas multiple style sheets is, as far as I’m aware, really
there for juggling CSS styles.
For the record, I don’t think that’s why you were having trouble. I
suggested not going down the multiple style sheets route because I
was sure we could come up with a much simpler way for you to get
things working.
k
On 3 May 2010, 12:57 pm, thatkeith wrote:
For the record, I don’t think that’s why you were having trouble. I suggested not going down the multiple style sheets route because I was sure we could come up with a much simpler way for you to get things working.
k
Yes, naming conventions will certainly suffice. so thanks for reminding me to get back to my roots.
I’m not nearly expert enough to wrangle multiple CSS style sheets for one site. Inheritance is crazy enough with one sheet active!
Once you grok it, inheritance is pretty simple. But actually, much of
the time, I find it simpler not to try to plan for that too much -
just work more or less as you would in a well-produced print DTP job.
Sure, web ain’t print. But design is design - and there’s far more
conceptual overlap than most web-only producers realise.
k
