I have an inline site.
It seems that on my not so long pages the footer is not sticked to the bottom of the screen.
It looks as if the footer is glueed to the divs above it, which do push it under, but the footer is not really on the bottom were it should be.
Well, on a big screen (27 inch iMac) there is a small white section under the footer, as if the footer is attached to the content above, instead of fixed to the bottom of the screen. When I have smaller content the footer moves up together with the content.
But if you say my construction is as it should be, I have to be satisfied and then I better change the page and add some content in the middle section to lengthen the page.
Because all longer pages (the blogs) are allright on the bigger screen.
