Omar_K_N1
(Omar K N)
January 15, 2011, 10:59am
1
Hi,
After the site is up & running, I just now discovered that the footer is still not pushed down in my inline-structure with RPL applied. Here is the code for the container (cont1) with col1 and col2 then the footer:
Any advice is welcome!
bw, Omar K N
Robert_B
(Robert B)
January 15, 2011, 1:46pm
2
I had this problem when I had a Pass-Through graphic (or any graphic maybe?) in my footer container using RPL.
Don’t know if that’s the set up you have.
Bob
Omar_K_N1
(Omar K N)
January 15, 2011, 3:30pm
3
Yes the footer has a graphic (jpeg) as background-image and the container has another background-image, also a jpeg.
Could this be a hinder for the footer being pushed down?!
bw, Omar K N
Robert_B
(Robert B)
January 15, 2011, 3:55pm
4
Well, I couldn’t get it to work.
I think I got it to work when everything was inline (box model) and took RPL off.
Bob
Omar_K_N1
(Omar K N)
January 15, 2011, 4:38pm
5
Specification:
RPL on or off: same result
The footer is pushed down when I add one line of text, then press enter; more lines disappear under the footer, which stays put.
All layers have unspecified heights as it should be.
– Omar
(thought this footer problem was solved now … )
Omar_K_N1
(Omar K N)
January 16, 2011, 7:44am
6
Now I had a look at the 3 Row_Three Column.freeway file , provided by Softpress, which is the basis of my structure, and it behaves exactly as described above (no. 2). So it doesn’t really work with longer texts!
= when entering more text into a column, then this column disappears behind a static* footer!
(footer moves only one line down. )
What would be the solution for this problem?
– Omar
