I have created a form on a page and would like to make the Submit button much bigger with a green background. The site is responsive btw. On a cell phone it looks a little different. Just unable to make the button larger for computer viewing. Will I need to get CSS out? thanks
Yes, you need to either add some hand-coded CSS to the page, or break out the Form Element Styler - ActionsForge Action. Note: changing buttons from their default appearance can lead to user confusion, so be tasteful.
You can do this directly within Freeway (since version 6):
Set the button to have a defined width and height (click on the Width and Height buttons in the Inspector palette)
Resize it to whatever size you want
Set the Colour to be Green
Jeremy
β
