Hello. This is a question I cant solved since some time ago. I cant manage with input text sizes when Im making a form, because althought I set the same size for them, when published, all became differentes from the others… so Im thinking in making them invisible and set a line just to say where to write, put I have no idea of where can I set the inut boxes to 0% opacity. At the palette you can turn it to 0% but then, you cant read when you write…
If there was a posibility to make the boxes same sized… it would be great. Is there any?
What version of Freeway are you using? There are Actions for 5.6 and lower, and 6 includes this functionality natively.
Let me clarify. Freeway 6 styles form elements using CSS, so the dimensions should be rock-solid in all browsers.
But I never get same sized in the input text. Perhaps is because I dont know how to style them properly.
Max gave to me the solution to style them to make them transparent, but Im still trying to make them same sized. In the next “row” I will investigate more deeply.
