To those using FTG I’m curious to know how you like it. It seems that it saves a lot of time. I also want to know if it is for data entry only or can it actually retrieve data from a MYSQL database.
Hi,
I use it and I like it. It should really be bundled with Freeway IMHO. It’s just for data entry - you’ll need to use something else to get the data out.
