[Pro] Fotomoto
I’m starting to build a site using Fotomoto. I have uploaded a few photos and copied their script into the HTML markup. The photos appear and the code works. However the buy buttons are out of alignment and I’m not sure how to adjust them. Does anyone know of a tutorial on using Fotomoto with Freeway?
I wrote to tech support at Fotomoto. Their advice is-For Fotomoto to work properly, images should be separated in the code on the page. We recommend that each image be contained within an HTML paragraph tag (P) or a DIV (DIV).
All I hear is “Greek” I’m a bit over my head with this one. Thanks for your help.
http://markbausman.com/sports.html
Try adding your images as backgrounds to Div containers to see if that helps.
