since yesterday freeway 5.5 do not start anymore I get the info program was interrupted I need help
email@hidden will be your best bet for a problem like this. Have you tried downloading the latest version or reinstalling Freeway?
Hello Joe,
yes i did it 3 times without success.
I did it from the original CD i#ve got from softpress and i downloaded the latest version.
I have no idea what i should do now.
thanks
It seems that no other have this problem. I could not get help from application system. who can help me?
Your in the correct place what is your problem?
Problem description?
Version of Freeway?
Express or Pro?
Version of Mac OS?
Hi Gerhard,
If you contact our support team directly, they can help you out:
Hello
I cannot start Freeway 5.5 Pro(5.6.4) Message " Freeway 5.5 wurde unerwartet unterbrochen" “Freeway 5.5 Pro was unexpected interrupted”
I already repaired all fonts and I tried to remove the freeway 5.5 Pro preferences, but I could not find a file with this name on my PC.
I also downloaded the latest version from Freeway 5.5 pro without success. I have no more idea what to do.
I need help.
Hi Gerhard,
Download the free tool AppCleaner, its free:
http://www.freemacsoft.net/appcleaner/
With Appcleaner you can delete Freeway with al the related files, your sites will be untouched.
Then re-install Freeway
