I have created a website a while back using freeway 5 and now I want to update it adding a gallery or a slideshow with showcase.
The problem I am facing is that opening the same file with freeway 6 it is behaving a bit strange, mostly the target show/hide layer actions don’t work. Is this a common problem and is there an easy way to fix it? Otherwise is there a way to make a slideshow or gallery in freeway 5?
