I have used Freeway 5 Pro for the first time with Mavericks and it bombs immediately I try to upload changes.
Does this mean that Freeway 5 is not compatible with Mavericks or is there a work-around?
I’m afraid Freeway 5 does indeed have a problem with crashing on upload in 10.9. You’ll need to upload manually with an FTP application or upgrade to version 6, which comes with the added bonus of having loads of new features and enhancements over the version you’re using!
Cheers,
After just installing Mavericks, I made a change to a website in FW 5 Pro. Everything went smoothly, I was able to Save changes and Update, but when I tried to Upload the site, FW crashed and burned. Tried it again and the same result: Freeway quit with an error.
I brought up FW again and checked for Updates from the menu and another error. The program cannot even check for updates. Something is radically incompatible.
I also use Cocoatech’s Path Finder and it freezes on starting up and requires a Force Quit. Cocoatech has been working on the problem for weeks now and no fix.
