[Pro] Freeway 6 displaying WOW Slider incorrectly
Hi Everyone, I’ve got a slight issue with the way FW6 is displaying WOW slider:
This is a page done in FW5.6:
http://www.mpscreative2.co.uk/client/yf/1/index.html
The same page when opened with, uploaded from, FW6 has the WOW Slider-generated shadow missing (it looks like it’s not showing above the
that contains the code:
I know v6 handles box model slightly differently but do I need to do a bit of surgery?
Any help would be gratefully received.
Many thanks
Mark
Sorry that 2nd link should be:
http://www.mpscreative2.co.uk/client/yf/2/index.html
Mark, the links you provide show what is happening in FWP5 not Pro6 –
makes it hard to diagnose.
slider:
of surgery?
Many thanks
Mark
Okay, thanks for the second link.
What I can see is the div “BodyDiv” is covering your shadow. To fix this we
need to move the div “menuDiv” higher up the z-axis (that is, towards the
viewer). In CSS, the attribute for this is z-index.
Normally an item’s z-index can be set in Freeway Pro’s Inspector palette –
however, the option is not available with many popular construction methods
like inline layout. So, let’s cover how to set it manually.
Select the item “menuDiv” then choose menu Item > Extended…
In the Div Style pane, add a new attribute:
  Value: 99
This should fix it.
I also noticed a slight gap under the div “menu” when this was fixed.
Reducing the hight a pixel made me happier about it.
Thanks a million Ernie. I wondered if it was something like that but wasn’t sure how to cure.
Strange though that this doesn’t happen in 5?
Thanks again, I’ll give it a try when I get back to the office later
Mark
  Value: 99
This should fix it.
Hi Ernie - still no joy on this. I have added the code but still displaying the same. Any ideas?
Many thanks
mark
Sorry, Mark, but you’ve not followed my directions…
 Value: 99
This should fix it.
Here, to be more specific:
https://www.evernote.com/shard/s218/sh/897621e3-5544-40f0-870f-22528f3e2ba1/95454a08d30bef337565e5576c289854
A case of ‘less haste…’ :slight_smile:
Thanks Ernie, all perfect now
Mark
Navigating around the FWP Extended interface options can be confusing –
seems like I’ve noticed a trend with FreewayTalkers resorting to
screen-grabs to help illuminate things.
Best wishes,
Mark
