I have a website using CSS Menu version 3.0.3 in FW 7.0.1 and it behaves differently in FW 7.0.3 CSS Menu 3.0.4
While I don’t really use the CSS Menu action, it’s my understanding that the CSS Menu was specifically updated for the 7.0.3 version release. Hence, why it behaves differently.
I do not know what was updated about it or why. I’m simply stating the obvious.
Hi, updated to 7.0.3, “css menu responsive” is not working properly, click on a anchor link, page moves to the right place, but “responsive overlay” is not closing and closing button is not reacting. Works fine with 7.0.2. Made a test on an other mac, same result.
I’ve rapported this to Softpress.
The problem is on iPhone in FW 7.0.3, it seems to be fine on desktop browsers.
On mobile I go to hamburger if you just open and close its ok but if you click on a link the navigation only shows as the close icon and doesn’t refresh back to logo and hamburger.
Joe, I have also been working on a site with 703 and I find that the responsive menu on the index page keeps becoming ‘detached’ from the master and everytime I make a change to the menu on the master page, I have to go back to the index and re-tick ‘use master actions.’
Mark, I also found this out when I added a new page, for some reason I had to go back to each page and re-check and I had the other pages locked so I’m not sure what went wrong and how they unchecked themselves??
