[Pro] Freeway 7.1.1
Have most upgraded to the latest Freeway version 7.1.1?
I usually do right away but I held off this time because I read that there were issues with the update.
Some advice please. I have Freeway 7.0 and I know there are some bugs I’m dealing with in this version. Am I asking for more headaches with upgrading to 7.1.1??
Billy
took me a while to dig this out:
https://freewaytalk.softpress.com/thread/view/164132#m_164133
Unfortunately, as far back as I can comfortably remember, Freeway has always been a “save often, or be prepared to lose your work” kind of app… and 7.1.1 is no different. I have only really started using 7.1.1 within the last few weeks and have already had 3 crashes.
These crashes appear to be due to the same issues I had in 5.5 (which is the last version of Freeway that I used extensively).
Process: Freeway 5.5 Pro [505]
Version: 5.6.5 (5.6.5)
Code Type: X86 (Native)
OS Version: Mac OS X 10.10.5 (14F27)
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000020
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x95a280a7 objc_msgSend + 23
1 com.apple.HIToolbox 0x98a645a4 _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long ()(OpaqueEventHandlerCallRef, OpaqueEventRef*, void*)) + 36
2 com.apple.HIToolbox 0x988a2681 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2291
3 com.apple.HIToolbox 0x988a165c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 402
Process: Freeway Pro [1293]
Version: 7.1.1 (7.1.1)
Hi Scottin,
Can you send us (support(at)softpress.com) the full report with details (as many as you can remember) of the last things you did before the crash occurred.
Many thanks,
7.1.1 has fixed many issues that affected 7.0, and also has the ability to change text styling at different breakpoints. You should definitely update.
Cheers,
So should I assume that sites I created before Freeway 7.1.1 may have some width issues, background-size conflicts etc? I coded in some of that in extended items and stylesheets before this version. I noticed that Freeway now has the size property built in.
Billy
Having troubles with Freeway 7.1 Styling Text.
As default I have my text styles set for my site. I want to have my style to be different at the 375px mobile breakpoint. I cannot get this to work. If I change the style at 375, it changes it for all of my other breakpoints.
Help please.
Billy
