I am not a particularly experienced Mac user, only using it to manage our Freeway website. I have upgraded to Freeway 7 Pro from Express, but cannot see how to open our existing website in the new version.
Our website was built in Freeway 5.5 Express. When doing what you suggest (Applications > Freeway > Freeway Express) the file shown as “Freeway 5.5 Express” is in light grey and cannot be opened…
I think you may be confusing the Freeway Express application with the documents that it creates. If you launch Express, then hold down the Control key while clicking on the name of the file in the top of the application window, you will see the entire Finder hierarchy to the actual document file. I suspect it may be in your Documents folder, if you didn’t do anything special when saving for the first time. Once you puzzle out where that document is actually saved, you will be able to navigate to it in the Open dialog and open it normally. You will see a one-time warning that you are about to make the document unusable in Express. This is normal, and to be expected. A backup copy will be saved alongside the original, with [Express] in its name, so you can go back (albeit without any of the changes you made within Freeway 7).
On Mar 27, 2016, at 7:14 AM, Martin Emery email@hidden wrote:
Thanks, David. I already tried that.
