[Pro] Freeway and Exhibeo 2
Freeway always adds the name/ID before the file names of the individual images of an Exhibeo2 gallery when exporting. This will not display the images. What am I doing wrong?
Freeway 7.1.4 (7070)
Exhibeo 2.0 (2088)
macOS High Sierra
the name of the Exportfile in Exhibeo and the name of the exportfile in the Exhibeo Import Achtion needs to be the same. If you set both manually it should work.
Thanks for pointing that out. That’s how it works. Unfortunately, this is not mentioned in the manual. This is probably a bug, because with Exhibeo 1 a manual adjustment is not necessary.
